My phone no longer charging and no usb c device is working with it
I can only charge my phone using the wireless charging. What can i do to fix it? i tried cleaning the port
Esta é uma boa pergunta?
@cliftonsammut sounds like a bad charging board. In the case of your phone the charging port is soldered to the daughter (sub board), I would suggest replacing that board. Use this guide OnePlus 9 5G Daughterboard Replacement for that. Replacement boards are readily available at many online stores.
Of course, there is always a possibility that this is caused by a failed flex cable from the main board to the daughterboard. Make sure it does not have any tears and it is properly connected etc.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 17
