Ir para o conteúdo principal
A Samsung anunciou a linha Galaxy Z Fold5 no seu evento "Unpacked" em 26 de julho de 2023. A nova série de smartwatches Galaxy Watch 6 e os tablets Galaxy Tab S9 também foram anunciados.
Wifi And Bluetooth Not Working
My Wifi and Bluetooth on Fold 5 is not working. it was working up untill now but now it is not working when i click the Wifi and bluetooth button it is greyed out. PLEASE HELP
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
5 respostas
The phone is most likely faulty - take it into your local store to get it replaced
Esta resposta foi útil?
Pontuação 0
Its the ribbon cable which is degrading causing the Bluetooth and WiFi not to work
Pontuação 0
Well update the phone to it latest software version sometime outdated version can also cause this kind of issue.
Pontuação 0
I have the same issue and tried different software solutions and quite often is starts working out of the blue. Also i noticed when i move or drop the phone then bluetooth gets disconnected so Its most likely an internal hardware issue. I'll be checking furthur how to open the phone carefully and see where the connector is of bleutooth/wifi, perhaps its not connected properly.
Pontuação 0
Restart your Galaxy Fold 5 first, then reset the network settings and check if Wi-Fi and Bluetooth become available. Booting into Safe Mode can help determine whether a third-party app is causing the issue. If both options remain grayed out after these steps, the problem is likely hardware-related and requires professional service.
Pontuação 0
Adicionar a sua resposta
Mustafa Chakkiwala será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 43
Últimos 30 dias: 119
Ao todo: 1,210
