Ir para o conteúdo principal
Smartphone da marca chinesa, utiliza o AndroidOne, parafusos Pentalobe frontais
Why can't I press the screen?
Cannot be touched Screen Cannot be touched
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@pekorasableng sounds like a failed touch screen. The touch screen is part of the display assembly. Time to replace the display assembly and while you do so, check the touchscreen connector on the motherboard for any damage, corrosion etc.
Since iFixit does not yet have a specific guide for this, use something like this guide It is written in Spanish, so you will need a browser that does translate it for you, if needed.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Pekora Sableng será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 167
