Black screen after display replacement
I’m attempting to fix an iPad Air 4 for a client, but the iFixit display is only responding with a dim backlight and is not producing an image. None of the board connectors appear to be damaged, and the factory display was working before one of the cables tore when attempting to apply glue strips. Does anyone know what the cause could be?
Esta é uma boa pergunta?
Wait did you tear a cable while doing a repair or did you do the repair because the cable tore?
Also check if the pins are damaged
por Hampter
