Ir para o conteúdo principal
Guias de reparo, manuais e ajuda para resolução de problemas dos fones de ouvido on-ear JBL Tune 520BT, lançados em 2023.
One side sound brack
One side having sound break
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
2 respostas
hello, i had the same problem. In my case, the issue was the cable between the left and right speaker being in tension. The solution in my case was to open the headband. first you have to remove the foam part, try to slide a sharp object like a flat screw driver into the seam between the foam part and the frame. Make sure you driver is under the foam part and then drag the screw driver along the seam to loosen the adhesive. Now remove the foam part. you can now loosen the cable to give it more slack. you can now reinsert the foam part. if it still doesn't work, i sadly can't help you.
Esta resposta foi útil?
Pontuação 0
JBL tune 520BT LEFT SIDE SPEAKER NOTE WORKING AFTER SOME TIME PLEASE TELL ME THE BEST REPAIR HOW?
Pontuação 0
Adicionar a sua resposta
Abhishek Yadav será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 74
Ao todo: 1,383
