has a e100 error
i just replaced the disc drive and motherboard and i when i start it up it says turn of and i press it and it dont turn off and i took a diffrent hdd from my pc and put it on it and it didnt work either i need help
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi Betty, I found this:
E100 is core firmware update fail, specific parts and errors are indicated with the two hex parameters behind it, but most common ones are disc drive missing or mismatched.
There is a code after the E100, we need that code. Can you provide the code? Thanks!
por Compartilhar
Adicionar um comentário
