How to fix the booting loop?
i just reset my phone and then the screen is not changing anymore i try to use the recovery mode but it didnt work
Esta é uma boa pergunta?
Hey hi zyro, the only thing I can suggest you at this point is a hard reset.
To do a hard reset, following the given steps:
1) Shutdown your phone
2) Put it in recovery mode (I assume you know it because you saved you tried putting it in recovery mode)
3) Wipe data or just do a factory reset
4) Reboot the system
If Hard reset also does not work then it might be just software update, also try charging the battery for a while (irrespective of it showing a sign of charging or no, just put in the cable, turn on the charger and take it back off after 20mins)before attempting a hard reset.
Thank you for reading and have a gorgeous day =)
Esta resposta foi útil?
Well I will suggest you to checkout the following video:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 37
Ao todo: 959
@oldturkey03 the robot got my one of the comment and I am running low now. Please have look at it. Take it back, read it (as it is for you only) and then I will delete it
por ᴘʀᴀᴠɪᴛ ʜᴀʀᴤʜ Compartilhar
