Ir para o conteúdo principal
The Bauker PGA115G1.2 is a 750W, 115mm angle grinder with an M14 spindle thread.
1 Perguntas Visualizar todos
Kenapa gerinda berbunyi kasar dan tidak berputar?
Gerinda saya berbunyi kasar dan tidak berputar
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@hermanus2855148 it'll depend on what that noise sounds like. If it is a loud humming, it could be a seized motor. If it makes a loud, different noise then it is absolutely possible that your grinder has issues with the bevel gears. Time to take it apart and have a look at it. You've selected the Bauker PGA115G1.2 as your device. for that use this teardown Disassembling Bauker PGA115G1.2 Angle grinder The only thing you want to do different, is that you only need to open the front part of the case, which contains the gears. Start at Step 10 and remove the 4 screws that hold the bevel gear (marked with blue arrows. there are 2 more on the other side,that are not visible )
then the one that hold the transmission casing to the grinder.
Once you have it apart, check for stripped gears etc. You can always post pictures of what you find etc. with your Question so we can try to help you further, Adicionar imagens a uma pergunta já existente
Translation
@ hermanus2855148 itu tergantung pada suara apa yang terdengar. Kalau bunyi senandungnya nyaring, bisa jadi motornya macet. Jika mengeluarkan suara yang keras dan berbeda, kemungkinan besar penggiling Anda memiliki masalah dengan roda gigi bevel. Saatnya membongkarnya dan melihatnya. Anda telah memilih Bauker PGA115G1.2 sebagai perangkat Anda. untuk itu gunakan pembongkaran ini Disassembling Bauker PGA115G1.2 Angle grinder Satu-satunya hal yang ingin Anda lakukan berbeda adalah Anda hanya perlu membuka bagian depan casing yang berisi roda gigi. Mulailah dari Langkah 10 dan lepaskan 4 sekrup yang menahan roda gigi bevel (ditandai dengan panah biru) lalu sekrup yang menahan selubung transmisi ke gerinda.
Setelah Anda memisahkannya, periksa apakah ada roda gigi yang terlepas, dll. Anda selalu dapat memposting gambar apa yang Anda temukan, dll. bersama Pertanyaan Anda sehingga kami dapat mencoba membantu Anda lebih lanjut, Adicionar imagens a uma pergunta já existente
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Bauker PGA115G1.2 Angle grinder Switch, rotor and stator
Guia
Fácil
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Hermanus28 Hermanus28 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 28
Duração total: 160
