Ir para o conteúdo principal
O Amazon Fire Max 11 é o tablet de 13ª geração produzido pela Amazon. Modelo: SU8NST
Best Option for opening the case.
I really need to get inside this tablet to fix a stuck power button. It is an all aluminum case, like so many other laptops and tablets, but I can't find any good tips on getting this think opened. Really could use some tips to get started and I will share experience.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Did you miss the iFixit guides available on the device page linked to at the upper right corner of your question? The LCD replacement guide shows you exactly how to remove the screen, and as @chrispautler pointed out, then you can access the internals.
Amazon Fire Max 11 LCD Touch Screen Replacement - iFixit Repair Guide
Esta resposta foi útil?
Pontuação 1
On this device, you have to pull the screen. Then you will have access to the internals.
Pontuação 0
Adicionar a sua resposta
Don será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 242
