Ir para o conteúdo principal
Lançado em julho de 2018, o MacBook Pro de 15", modelo A1990, possui uma tela de 15,4 polegadas com retroiluminação LED e tecnologia True Tone, TouchID e processador Core i9 de até 6 núcleos.
Need help diagnosing display issues
My 2018 MacBook Pro display is shpwing flickering green and red lines, and occaionally blacks out or has a block pattern. I cannot locate any cracks in the screen, and the laptop has not been dropped since I have owned it. Graphics display perfectly when using Airplay to cast to my TV. Does this seem to indicate a display cable issue, or should I be looking at replacing the screen? Thanks in advance for the help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
This is most likely due to a failing display flex cable, which unfortunately is integrated into the display assembly. This is a common design problem with these models (2016-2018ish Pros). Unfortunately you'll need to replace the display assembly to repair the device. Sorry!
Esta resposta foi útil?
Pontuação 1
1 comentário:
That’s what I thought originally, I just needed some confirmation before I under the process. I already bought a replacement display as simply, I just had not installed it. If there was any other options, I wanted to explore that first. Thanks a bunch!
por
Imagem
Saludos que me recomienda MacBook Pro 2018 15 pulgadas modelo a1990
Pontuação 0
Adicionar a sua resposta
Tanya Robinson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 23
Ao todo: 281
