Ir para o conteúdo principal
O Palm Zire m150 é um PDA portátil com tela sensível ao toque. Foi fabricado pela Palm em 2002. O PDA possui 2 MB de RAM e 2 MB de memória instalada.
Acceptable Battery Replacement on Amazon?
Hello :)
I recently got hold of a Palm Zire m150, but the battery is no good. I found a replacement battery on Amazon: (https://www.amazon.com/GAXI-Battery-Repl...). I would think that this is the right battery, but I am just making sure (for the safety of me and my Zire).
Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
There should be nothing wrong with that battery - I've used CS batteries many times with no issues.
Just note that this battery requires soldering, and be prepared for that.
The seller is someone called "GAXIN" and they have a very short duration on Amazon and little feedback. Not sure if you can find some equivalent from a more reputable vendor. Not that I am saying anything bad against GAXIN, they may be a perfectly reputable vendor just getting their start. But until you know, or they've built a good reputation, you simply never know.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
_nec6678 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 18
Ao todo: 345
