Ir para o conteúdo principal
Informações gerais sobre o "Logitech G102 Lightsync" (mouse gamer com fio)
Mouse scroll wheel not work properly
The scroll wheel glitches up every now and then.
Everytime I scroll down on a page it suddenly starts scrolling up for a split second on its own and then back to normal and it happens very often
Esta é uma boa pergunta?
Pontuação 12
Adicionar um comentário
2 respostas
Pergunta mais útil
Hey hi 💫Muhammad Ibrahim Khan💫, nice to know that your having a Logitech G102 Lightsync, It's a pretty good mouse and a high-spec one. I was looking for it online yesterday but got eye on something else
Anyways coming back to the question, this problem is quiet common in mouses. Even I have it my amazon basics mouse, but I got it fixed using a simple tip. The following are a collection of tips you can use to get your Logitech G102 Lightsync mouse's scroll fixed👇
  • 🌟Vigorously Scroll the Wheel🌟 ----(🎗️THE MOST HELPFUL AND EFFECTIVE🎗️)----
# Turn your mouse opposite and glide it on the scroll through your desk at high speed multiple times. This will fix your scroll issue probably, as it did mine. It is because of the copper layer oxidizing.
  • Clean the scroll wheel
# Just get your scroll wheel cleaned champ, you can do it by blower or a brush. Even this can get your mouse fixed.
  • Update your Mouse Driver
# You can get your mouse driver updated by clicking here and updating the mouse driver from the site you just visited by clicking😜
These 3 things are enough to get your mouse scroll problem fixed. Also to new people, the solutions given, except for the 3 point is universal and works for any mouse and not just Logitech G102 Lightsync. If you have any more queries or doubts, we are here to help. Feel free and don't hesitate on commenting!!! I really hope you loved the answer. 🌟Thank you for reading and have a gorgeous day🌟
Esta resposta foi útil?
Pontuação 18
7 comentários:
Thanks Pravit. It worked as you mentioned. 🌟 +1 for your answer.
por
Thank you @iprocessor, nice to know that it worked and I really hope you are having a nice day😊
por
谢谢你,好心的神😭😭😭
por
Thankyou its working <3
por
спасибо, легенда, очень помог
por
Exibir mais 2 comentários
This can have two types of problems: one could be the wheel itself, and the other could be the three-pin mouse encoder. The issue might be in either one of them, or possibly in both.
Because the front point of the wheel is made of plastic, it can sometimes break. So, you should search for that wheel online—you can easily find it anywhere. Then, you just need to replace it.
The same applies to the encoder as well: if your three-pin mouse encoder is damaged, you can check its size (in mm), purchase the correct one online, and replace it.
Imagem
Imagem
Pontuação -1
Adicionar a sua resposta
Muhammad Ibrahim Khan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 17
Últimos 7 dias: 45
Últimos 30 dias: 197
Ao todo: 5,202
