Ir para o conteúdo principal
Vertical dark shadow bar across LCD display
50-inch 1080p LCD display displays a vertical dark shadow across the center of the screen. Sort of like this person's display: Samsung UE49KU6400 shadow issue
My TV is around 6 years old, and just got this shadow about 2 days ago. It's never had any issues other than video processing issues that started around 3 weeks ago. I want to say that the 2 issues are connected, but any DIY attempts to fix it haven't worked.
Have powered on and off the TV, unplugged it and plugged it back in, & reset the TV to factory defaults. And, have tried everything else. Dont know what else to do.
How should I fix it, without spending too much money?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
@alfredhitc80085 just like the Question you've linked to, your's looks like a failed LED’s on the edge backlight strips as well. Replacement strips are about USD $25-$40 You could use something like this guide Samsung Television UE49KU6640 Backlight Replacement or use this video since it is identical to your model.
Esta resposta foi útil?
Pontuação 1
Short answer: reach for the edge LED strips, test them with an LED tester, bridge the open LED or replace the faulty strip(s)
Pontuação 1
Adicionar a sua resposta
Alfred Hitchcock será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 135
Ao todo: 1,630
