Ir para o conteúdo principal
MacBook de 13" com corpo monobloco de alumínio, processador Core 2 Duo de 2,0 ou 2,4 GHz.
Optical Drive Not Making Sound at Startup
Hey guys, weird issue. I just replaced the logic board on this MacBook, and now the optical drive makes no noise at startup. Before, you know, there would be a humming and clicking sound and eventually the Startup Chime. Now, just the startup chime. The optical drive works just fine. But, the old logic board will activate the optical drive at startup whereas the new one will not. Everything works just fine, and it doesn't seem to be affecting anything else, I was wondering why it's not doing anything. And, if this is a problem, how could I fix it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
@danj & @livfe - Turns out is was a firmware issue. My Mac’s firmware was at 1.2, and I needed to update it to 1.4. That’s all it took. The optical drive now sounds great at startup! It’s funny how some of the strangest issues have the most simple fixes!
Esta resposta foi útil?
Pontuação 1
What you are seeing (really not) is the pecking order of the drives is no longer set to check the optical drive first. Going into the Startup Prefs allows you to alter it.
Pontuação 0
31 comentários:
@danj - Where would I change these settings?
por Compartilhar
@jadonlyon System Preferences / Startup Disc / Unlock and highlight the drive ?
por Compartilhar
@livfe - No luck there :(
por Compartilhar
@jadonlyon I wish my 8 'funny' units were that easy to fix..... Love that sound of a mac bootup :)
por Compartilhar
@livfe - Never ever gets old :)
por Compartilhar
Exibir mais 26 comentários
Adicionar a sua resposta
Jadon Lyon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 383
