Ir para o conteúdo principal
The Xiaomi Poco X3 Pro is an entry level smartphone by Xiaomi released March 2021. It is equipped with a 6.67" IPS LCD screen, a 48 MP main camera and runs on the Qualcomm Snapdragon 860.
Why does WiFi not work?
My phone is Poco X3 basic version
A year ago my WiFi stopped working
Only my House's WiFi would work and no else WiFi I then started to use Mobile data
Even the hotspot won't work and after sometime the Bluetooth stopped working too
The phone didn't had any changes and it's performance was great
I asked a guy he said that there is a software issue but he couldn't solve it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @mrreaper13236
Try using the phone's WiFi (or BT) as close as possible to your home network router (or BT device) i.e. <10cm and check if you get a stable connection.
If you do it may be an antenna problem in the phone. Loose connection perhaps.
Here's an image taken from the ifixit Poco X3 Pro Screen Replacement guide] showing the location of one end of the antenna. The other end is under the module.
(click on image)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
MR REAPER será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 201
