Ir para o conteúdo principal
No image on screen need help
Camera is shooting but wont display image on the screen
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Is it taking the photo
If you have an SD card connect it to your computer, see if it is taking photos of just if the screen is dead
por
Adicionar um comentário
1 resposta
Pergunta mais útil
If you pressed the INFO button, it can cause the screen to go black while taking photos. You can try pressing the INFO button to see if that brings back the screen. It's also worth pressing the MENU button to see if you're able to bring up the menu on the screen or not.
Otherwise, try shinning a bright flashlight at an angle to the LCD screen to see if you're able to make out a dim image. If you can, the issue lies with the screen's backlight.
It could also potentially be worth removing the back cover and checking to make sure that the screen's ribbon cable hasn't come loose at all.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
DEXTER HOLGADO será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 255
