Hi @albertoarthas
Unfortunately, De Longhi doesn't provide service manuals so there's no schematic diagram for your oven that I can link to show you how it works.
Basically, in microwave ovens it is the magnetron that produces the microwaves that cook the food. This is powered by a High Voltage (HV) transformer, diode and capacitor network which provide the necessary voltage i.e. ~5000V DC for it to work.
The HV power circuit is controlled by the control board and there are also door switches involved that should turn off the power to the magnetron and the turntable if the door is opened whilst it is cooking. These switches are a safety feature, used to prevent harmful microwave radiation escaping from the oven cavity when it is operating. The oven cavity becomes a Faraday cage which prevents the microwaves from escaping when the door is closed.
So it could be faulty door switch(s), a faulty control board, or a faulty component in the HV circuit i.e. HV transformer, HV diode, HV capacitor and the magnetron.
Sorry to be so vague but without a wiring diagram, you would need to check all of the components mentioned to find out what's wrong
Here's a parts list that may help.
Be safety aware if you decide to open the oven to see what may be wrong. The HV capacitor in the oven can store >5000V DC for months even if the power to the oven has been disconnected for this length of time. This amount of voltage can seriously injure you. The HV capacitor needs to be correctly discharged as soon as it can be accessed after removing the cover from the oven and before any further work inside the oven is carried out. If you don't know how to do this then call a reputable, professional appliance repair service and ask for a quote
3 comentários
Hi @albertoarthas
What is the make and model number of the oven?
por jayeff
De Longhi MWJ62
por Alberto Signoretti
https://www.newricambi.it/cucina/forni-a...
you can check the model in this site here
