Keyboard keys pressed automatically
Many keys are functioning automatically so currently using powertool application to disable the key, need a better solution
Esta é uma boa pergunta?
It sounds like you might be experiencing a hardware issue with your keyboard. Before resorting to software solutions like the Powertool application, try cleaning your keyboard thoroughly to remove any debris or dust that might be causing the keys to stick. If the problem persists, you may need to consider replacing the keyboard altogether.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 225
