Ir para o conteúdo principal
Sony Alpha a6400 / ILCE-6400.
Screen doesn't working after falling
Hi! I dropped the camera without protection on stone floor. After that, everything is functional still but the screen doesn't turn on anymore. There are no visible damages to the camera itself, nor the ribbon or the screen. Any guesses on that? :(
Here's a video showing the camera:
https://drive.google.com/file/d/1I42ryWT...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@gabrielblauth not every display error will show externally. I would at least start with the screen. Of course, make sure that all cables are still properly seated and did not get dislodged etc. It's always best to remove them from the connector and then reinsert them just to verify, proper connection is made.
GO to the device page Sony a6400 and scroll to Documents. There you'll find the service manual for the camera. It will help you with the repair of the LCD. While you are disassembling it, double check all flex cables and check for any unusual or damaged looking components.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Any update or report on this as I have a similar issue?
por Compartilhar
Adicionar a sua resposta
Gabriel Blauth será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 41
Ao todo: 965
