Ir para o conteúdo principal
Sales of the second generation model started with model year 2000 and production ended with the 2005 model year. The second generation Neon was only available as a four-door sedan.
12 Perguntas Visualizar todos
Are these two hose connections correct and also what part is this?
I am unsure if these two connections are in the correct spot please advise if they are or not. Also the part I am unsure of that needs repair is on the front right wheel drivers side.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Can't tell you about the hoses; it's been way too long since I've worked on a Neon, but the broken part you're referring to looks to me like the rubber boot that's supposed to be covering the constant velocity joint. If you go online or to an auto parts store and ask for a CV Joint boot for the front left wheel, that should get you the part you need.
Couple of notes here, though; you said it was the right, driver's side, both of which can't be correct. Whenever you refer to right or left on a car in reference to parts, it's always from the perspective of sitting in the driver's seat, so the left front wheel will be the one on the driver's side, and the right front wheel will be the one on the passenger side.
Secondly, chances are pretty good you'll need to specify whether it's the inner or outer boot. Most CV axles come with two boots; one that installs in the transmission (the inner boot), and one that connects to the wheel itself (the outer boot). So you'll need to specify which one it is in order to be sure of getting the right part.
Good luck, hope that information helps!
Esta resposta foi útil?
Pontuação 0
2 comentários:
Hi @dadibrokeit,
Depends on your world perspective ;-)
There were RHD Neon cars manufactured.
Cheers
por
@jayeff Yes, you are absolutely correct, but odds are good we're talking about a left hand drive car; if it was a RHD vehicle the owners tend to mention that.
So yes @erickhdez1226, if you have a car with the steering wheel on the right hand side, then your comment on the "front right wheel drivers side" would be correct; otherwise it should be left.
por
Adicionar a sua resposta
Erick Hernandez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 29
