Ir para o conteúdo principal
Informações de reparo e desmontagem do smartphone Android Samsung Galaxy S21 5G, incluindo o modelo SM-G991U.
WI-FI constantly turning itself off
Okay so I got this phone second hand, it is the Galaxy S21 FE 5g, the wifi constantly turns itself off after about 10-15 minutes on the new ui 6 update, i’ve been through all settings involving samsungs smart connect, and factory reset multiple times. no cracks or outside damage. the bluetooth is fine so I know it’s wifi specific and happens on every network. it’s not my main phone but I would like to invest a little into fixing it, I just don’t know what i’d need to replace or if samsung is still as repairable as it used to be, i’ve had an iphone as my main for quite a while now
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Check for any battery saver settings being turned on... it might be that it's turning off the wifi to conserve power.
Esta resposta foi útil?
Pontuação 1
4 comentários:
Did you figure it out ? Mine is doing the same
por
I changed the power saving to high performance and it fixed the same issue I was having with the wifi turning off
por
I'm having the same issue
por
Same issue, and non of the solutions work.
por
Samsung has tech support for that. Not the sharpest knife in the world, but it is free and they can log onto your phone and look at it.
That is your best option.
Pontuação 0
Adicionar a sua resposta
dominick giovannelli será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 41
Ao todo: 1,521
