Ir para o conteúdo principal
The smaller, economical version of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
20 Perguntas Visualizar todos
My phone isn’t turning on or charging
I tried replacing the battery but still nothing. Phone won’t turn on or even charge, even with tap to charge I get nothing.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
@thereaper58889 this "isn’t turning on or charging" and a new battery not working, sounds like a no power issue. Use these guides Samsung Galaxy S10e to work on you phone. Follow the Samsung Power On flow chart and see what you get.
Measure the components as listed on the flowchart. Use the search function of your PDF reader to locate teh components needing to be checked, on the board. Galaxy S10e Component Layout
Let us know what you find out. If you are stuck with anything or need to know anything about the board etc. post some good images of your boards with your Question.
Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
2 comentários:
I am having the same issue here; I've torn down the phone to the motherboard, but I can't figure out how to remove the metal plates covering some of the components the flowchart says to test
por
@wolfkid13 we would have to see the shields. Some are soldered on and some have a pressed lid on those. If they are lidded a small screwdriver is needed to pop them off.
por
Adicionar a sua resposta
34 TheReaper será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 160
