Ir para o conteúdo principal
Informações de reparo para a TV LCD Sony Bravia 32". Lançada em 2008. Número do modelo: KLV-32T400A.
Tv will be automatically off
TV it will be automatically off
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@santoshull69133 what is the exact model number for your TV? What have you checked? What have you tried? Explain to us exactly what happens. You chin your TV on and it turns right back off? Does the power LED blink? Any specific code?
por
Adicionar um comentário
1 resposta
Firstly, check if you have unknowingly set an automatic shutoff timer in the TV settings. If that's not the case usually this symptom is indicative of faulty capacitors on the mainboard or power board of the TV at least with Samsung TV's. I suspect similar symptoms could occur on Sony TV's as well, If you're comfortable with doing so, you can open up the TV and check for any bulging capacitors on both the mainboard and the power supply board.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Santosh Ullagaddi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 204
