Ir para o conteúdo principal
Repair guides and manuals for the Craftsman Chain Saw 358356332 2018.
2 Perguntas Visualizar todos
Gas line pops off of carburetor when pressing primer bubble
Gas line pops off of carburetor when pressing primer bubble. What causes this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@chrischand74500 the primer bulb should push only air back into the fuel tank when depressed. As it now re-inflates it sucks fuel from the tank into the carburetor. If it pushes your fuel line off, then it is pushing quite a bit of air. Could just be a fuel line that is to loose. Make sure that your carburetor bowl is fuel and the float and needle valve are okay.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Chris Chandler (CMFC) será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 30
