Ir para o conteúdo principal
O PlayStation Vita é o sucessor do PSP. Ele contém um processador e gráficos aprimorados e inclui a adição de uma segunda alavanca analógica. Ele foi lançado em 15 de fevereiro de 2012.
Ps vita not charging
Hello,
i have a ps vita that has stopped accepting a charge, i opened up the vita, disconnected the battery, reconnected it, then closed it back up. I checked by plugging it into a charger and it started charging but when i took it off the charger, after a while it wouldn’t charge anymore. I used an application called battery fixer on the vita that worked for some people and it didn’t work. I also tried multiple chargers and no luck. Is this a battery issue? I also want to know if anyone else had this issue so i know im not alone. I asked chat gpt and it said get a new battery but because first of all ai isn’t that smart yet and because i live in the uae and its hard to find any device batteries in the uae.And someone please tell me were to get a ps vita battery in the middle east.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hello,
I'm serious when i say this, but it happend to me just like that. I wanted to ask you if you did end up changing the battery and if it helped since i also wanted to do the same to hopefully fix my vita.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
Pretty sure it's the battery which is faulty (especially when you tried multiple chargers).
The battery need to be replaced, so it can charge normally again.
Ifixit has a great guide to replace the battery for the PS Vita: Substituição da bateria do PlayStation Vita
And the good news that it's very easy to do too!
Now, I don't live in the UAE, but I know that AliExpress do ship worldwide (yes, batteries will take a long time to arrive, but it is possible!).
PS Vita 2000 battery: https://www.aliexpress.us/item/325680561...
PS Vita 1000 battery: https://www.aliexpress.us/item/325680614...
Those are examples. Please change your country, language and currency next to "login" in the upper right corner, so you can see if they ship to the UAE. Otherwise you could buy them on Amazon (if this is possible for you).
Good luck! Hopefully you have a new battery soon!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Moosa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 85
Ao todo: 2,268
