Is it possible to replace the hard disk with an SSD?
I would like to clone the current HDD with an SSD to make it faster.
Esta é uma boa pergunta?
@piero90 yes, you can. Now, with that said, it will depend on what motherboard/processor you have. If your motherboard does not have an M2 slot, you will need to get a 2.5" SATA3 SSD. Something like a Kingston’s KC600 would work
If it does have an M2 use the appropriate SSD for that.
"Support for 6.35-cm (2.5-in) SATA hard drives in 7.0-mm (.28-in) and 9.5-mm (.37-in) thickness Support for M.2 SATA storage (Port 0) (models with i7 processors and 4 GB discrete graphics memory only)" from the HP Envy Maintenance And Service Guide. Page 55 shows you how to check it out and to work on it.
Esta resposta foi útil?
Is the following docking station good for cloning laptop HDD to SSD?
@piero90 I have not use that particular one but use a similar setup daily without any issues.
@oldturkey03 thanks
@oldturkey03 Good evening, this SSD is good for notebook?
@piero90 Looks like it should work, 2TB :-) Awesome!
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 55
