Ir para o conteúdo principal
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
$50 Touchbar MacBook Pro blank touch and random restart issue?
I just got a MacBook Pro from a recycler for $50. It charges, I was able to reset OSX, and use it as expected except the Touch Bar is totally blank and I’ve had it restart stating an issue has occurred twice. I’d like to try to troubleshoot the touch bar first. I was wondering if anyone has some suggestion on what I should look at for this? My first plan of action tonight is to check the ribbon cable connector. I opened it up last night and it seems to be very clean overall with no appearance of liquid damage. I also noticed in the settings nothing for the Touch Bar show up? I’d assume this is expected if it’s not working? Thanks everyone!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
A common issue in the 2016/17 series is within the TouchBar microcontroller, reference Step 18 in the teardown here MacBook Pro 13" Touch Bar Teardown and in Step 20 you can see the touch controller which converts the touch into a digital input.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dasrainman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 117
