Ir para o conteúdo principal
Conversível de 15 polegadas da HP com o número de modelo 2PS98EA.
How to replace broken hinge?
my hinge is broken on one side. I've got it removed because nobody wanted to touch my laptop as it's touchscreen.
Esta é uma boa pergunta?
Pontuação 3
1 comentário
How do I repair winges on my Hp 15 bs144rm
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
I have done this repair and as someone who has done repairs on laptops for a very long time. This was my absolute least favorite repair ever. I ended up having to replace the entire screen as well as both of the hinges. This is a well known problem with this laptop which I suspect why no one wants to touch it. Even the slightest flex of the screen which must be taken out to do this repair will crack the outer layer of glass and you will end up having to replace it.
I would caution anyone attempting to repair this issue on the machine and would likely turn down the next one I see for repair as well. It is simply and honestly put not something that can be done easily and even when completed. I can see this happening again because of the poor design of the hinge system overall.
I'm not saying you cannot do it, I am saying go ahead and order an extra screen from the start. you are likely gonna need it.
If you do replace it moving forward after replacement use both hands always to open the screen equal distance apart as a single hand open will put more force on one of the hinges and this is how it fails.
I sourced the replacement LCD from here. https://www.ebay.com/str/ftdlcd both the screens worked fine and came pretty fast.
I sourced replacement hinges from here. https://www.ebay.com/str/honthstore they were identical to the originals.
If you have any further questions about this repair you can post back and I will do my best to answer your questions or even help you through a repair.
Cheers
Monte
Esta resposta foi útil?
Pontuação 6
2 comentários:
can confirm everything you said!! Dealing with one now
por Compartilhar
@jasnahodzic Jasna, we'd prefer you didn't ask for individual help and recommend you remove your personally identifiable information (i.e., your email address) from your comment. Holding a private conversation takes the information off the site, depriving others of whatever you might learn - that could help them as well. If you need more interaction than is available in a comment, I suggest you start your own question, where you can post pictures, videos, PDFs, and whatever else might help.
por Compartilhar
Adicionar a sua resposta
Sneha Yadav será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 78
Ao todo: 3,350
