Ir para o conteúdo principal
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Removing stripped screw from LCD Panel assembly: best strategy?
The machine is a Core Duo, last serial numbers RVMN.
While I was trying to execute the Fast LCD replacement guide, I was stuck because one of the topmost screws, the one closer to the iSight, on the left size is stripped. Basically, it hasn't its proper cross shaped head anymore, just some sort of conical hole.
I tried to get a drill, but the man who own the drill warned me that "The heat could even melt your plastic upper casing", so I was scared.
The space to work seems too small for a Dremel... has anyone removed a screw in such a tight spot?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
Use a new sharp drill bit made for cutting metal, not a wood bit. Go slow a let the bit do the work, it should cut the metal not smoke it. Please go to the guide an give me a link to exactly which screw you're talking about.
Here's some other suggestions on screw removal.
http://www.todayifoundout.com/index.php/...
Esta resposta foi útil?
Pontuação 4
6 comentários:
MacBook Core Duo LCD Panel Replacement
Step 50, the one at the left of the iSight, circled in red.
I fear damaging the LCD itself or the plastic case by drilling on it..
por
There are enough screws in this thing that leaving this one out probably won't matter much.
por
I know. My issue is about drilling close to the LCD: won't I end with a damaged monitor or case? If it's doable, I'd do a drill after the holidays.
por
Use a drill press for better bit control. The bit should be the same size as the screw shaft.
por
After holidays I'll ask for that drill, or find up a body shop willing to drill the bugger out for me. Then, I'll get all fixed nice. I can wait a bit... but your advice was precious, as usual.
por
Exibir mais 1 comentário
You could always give ifixit's screw extractors a shot. They work pretty well in tight spaces.
Imagem de Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm.
Produto
Precision Screw Extractor Set
$24.99
Pontuação 1
ainol professional brand website !
Pontuação 0
dremel emery wheel will cut a slot in a screw head; if the screw is too small use a flat-bottom 'end mill' bit with dremel and cut a slot, done this dozens of times.
Pontuação 0
Adicionar a sua resposta
Stefano Gigante será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 8,620
