Ir para o conteúdo principal
Por que meu celular não está querendo ligar?
Meu celular começou a reiniciar sozinho de madrugada quando estava carregando, pela manhã quando fui acessá-lo não quis ligar de jeito nenhum, tentei reiniciar, formatar e nada fez ele sair da tela preta. Poderia me ajudar?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@sales33652 this sounds like a power issue. Start with the common things. First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Ultimately it could just be a bad battery. Since iFixit does not yet have guide for this, use something like this video Batteries are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@sales33652 Parece-me um problema de energia. Começa pelas coisas mais comuns. Primeiro, verifica o teu carregador. Certifica-te de que tem uma saída adequada. Depois, verifica o cabo de carregamento. Verifica se os conectores não estão dobrados, etc. Depois disso, verifica a porta de carregamento. Limpa-a de quaisquer detritos, etc. Utiliza alguns sopros de ar para a limpar. Se nada disto funcionar, arranja um amperímetro USB e vê se o teu telemóvel consome alguma amperagem do carregador. Se não conseguir, é possível que se trate de um problema na porta de carregamento ou de uma bateria avariada.
Para verificar a porta de carregamento, utiliza um voltímetro e mede a tensão no conetor da bateria. Em seguida, liga o carregador do telemóvel. Mede agora a tensão no conetor da bateria. Essa tensão terá de ter aumentado. Se não aumentar, então o problema é a porta ou o circuito de carregamento.
Em última análise, pode ser apenas uma bateria estragada. Uma vez que o iFixit ainda não tem um guia para isto, utiliza algo como este vídeo As pilhas estão facilmente disponíveis em muitas lojas online.
Enquanto trabalhas no teu telemóvel, tira muitas fotografias. Quando acabares, tira essas fotografias e cria um guia para o iFixit. Isso ajudará a próxima pessoa que tenha um aparelho com os mesmos problemas que tu. É fácil e divertido criar estes guias. https://ifixit.com/Guide/new A comunidade iFixit vai agradecer-te.
Reparar é uma guerra contra a entropia!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sales será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 115
