Ir para o conteúdo principal
Steering and electric problems
The steering is so heavy and the camera is not working what cause this problem car tucson 2013 limited edition
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Greetings Otaku,
Have you checked the fluid level for the power steering fluid? Is the belt slipping or missing from the power steering pump? In addition to this a sudden heavy steering issue is a symptom of a failing or failed lower ball joint.
The camera I would start by checking fuses, wire harness specifically where the camera goes into the back trunk and connections.
Cheers!
Monte
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Otaku Gamesッ será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 32
Ao todo: 348
