Ir para o conteúdo principal
The Dell Chromebook 3100 2-in-1 was released in 2019 and can be identified by model number P30T001.
How to replace storage on the Dell Chromebook 3100 2-in-1
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
@li2 the 3100 uses eMMC storage which is soldered to the motherboard and it is not replaceable.
Update (04/07/24)
@li2 not on the Chromebook just on the card. Check the Dell Chromebook 3100 2 In 1 Service Manual toward the end it tells you how to do a reset and recovery. Hope it'll answer all of your questions.
Esta resposta foi útil?
Pontuação 0
8 comentários:
@oldturkey03 is it possible to unsolder the eMMC storage and replace it with a new one or it wouldn't work because the system wouldn't recognize it
por
@li2 it does not work that way. It's a different IC's then what you might be used too.
por
@oldturkey03 can you use a sd card and install chrome os on that would that work
por
@li2 it's got the card reader that you can (must) use to install your OS, so I do not see why it would not work. Just use a large enough card and go for it :-)
por
@oldturkey03 Thanks for letting me know but do you have to wipe the memory first on the Chromebook for sd card?
por
Exibir mais 3 comentários
Adicionar a sua resposta
li2 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 60
Ao todo: 878
