Ir para o conteúdo principal
Lenovo released the 25th-anniversary Retro ThinkPad 25 in October 2017. The ThinkPad 25 model is based on the T470 but includes the seven-Row “Classic” keyboard with the layout found on the ThinkPad —20 Series.
7 Perguntas Visualizar todos
Upgrade from wifi 5 to 6
I have a Lenovo Thinkpad 25. I wonder if it is ok to replace the existing wifi card Intel AC8265 with Intel AX200 in order to upgrade wifi 5 to 6. I am concerned about the compatibility issue arising from such a replacement. Would appreciate your kind advice.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@ddderek there is no reason not to at least give it a try. The cost for the AX card is not to high and I would definitely do it.
Just in case you need to know how to get to it etc. use this ThinkPad 25 Hardware Maintenance Manual and steps are listed on page 80
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
D D Derek será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 62
