Neither of my dual icemakers make ice, unless test button is pushed
I have a side-by-side Samsung fridge. It is equipped with dual ice makers. Neither will make ice automatically but will if you hit test button. This behavior started on both at same time. Ice cubes are solid. Have gone through all resets and disconnected the fridge from power. Also checked waterline and get full volume through water dispenser. After reset, the water fills, but does not dump the ice until I reset it again sometime later.
More info … I had recently started to periodically turn lower ice maker off on door panel due to little use
Please help.
Update (04/05/24)
I thought I had sent reply, but I don’t see it so here it is.
Model: RFG298HDRS
Esta é uma boa pergunta?
1 comentário
Hi @marksimpso11212
What is the full model number of the refrigerator?
por jayeff
