Ir para o conteúdo principal
12.1" business laptop released in June 2012 by Lenovo. This laptop uses multiple product numbers, which vary based on configuration.
Por que não liga?
Ao conectar o carregador o computador não dá nenhum sinal de corrente na placa, nem o culer gira
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@blackghost83658 Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
Use this Lenovo ThinkPad X230 Hardware Maintenance Manual to work on your computer. It is in English but hopefully still helps you out.
Adding images to an existing question
Translation
@blackghost83658 Começa com as coisas fáceis. Desliga a alimentação do computador, desligando o cabo de alimentação do teu computador. Desliga todos os dispositivos externos do computador. Retira a bateria Agora mantém o botão de alimentação premido durante cerca de 30 segundos a 1 minuto. Volta a ligar o adaptador de corrente alternada e verifica se o computador mostra algum sinal de vida.
Primeiro, tens de verificar a fonte de alimentação. Certifica-te de que tem as tensões adequadas. Verifica se os conectores não estão dobrados, etc. Verifica a tomada de entrada DC do teu computador portátil. Certifica-te de que não há corrosão, detritos, etc. que a impeçam de funcionar. Limpa-a de quaisquer detritos, etc., utilizando alguns sopros de ar para a limpar. Se nada disto funcionar, arranja um amperímetro e vê se o teu computador portátil consome alguma amperagem do carregador. Depois disso, tens de verificar se a tua placa-mãe recebe energia. Para isso, claro, tens de a abrir. Tira umas boas fotografias do que vês. Assim, podemos ver o que tu vês.
Utiliza este Lenovo ThinkPad X230 Hardware Maintenance Manual para trabalhares no teu computador. Está em inglês, mas espero que te ajude.
Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Black Ghost será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 36
