Ir para o conteúdo principal
Informações de reparo e desmontagem para a primeira geração do Apple Watch SE, anunciado em 18 de setembro de 2020.
Apple Watch SE resetting constantly
Repaired successfully my cracked Apple Watch SE screen, it paired correctly, but then after 5 minutes started resetting and continually is doing so. Tried:
Hard reset
Full battery drain/recharge
Factory reset, but now it doesn’t stay on long enough to pair.
Any advice what to try next? Screen works well and can select etc, just not able to stop it from resetting
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hey there,
to be honest there are atleast few posible reasons for such problem.
1- Battery problem: it may be problem with connector or battery it self.
2- Soft
3- display- it rarely happends that display cause logo loop so i assume it also could be reason for restarts.
4- Moather board problem.
You could try to open it again but if your not very expierienced with it, i would advice to leave it for some workshop for diagntostics, they are often done for free.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Andrew1drew será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 245
