Ir para o conteúdo principal
Stops mid-cycle and more
Similar symptoms, never any error codes. Replaced door latch to no avail. Ran installation diagnostics, and it doesn't complete test 10 (door latch test). Just sits there like when it stops mid cycle.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@chimes91508 this was left as an Answer to a 10 year old question. If you would like some help with that, let us know the exact model number for your Washer. Also, give us more of the issues that you have with the washer.
por
Adicionar um comentário
1 resposta
If it runs at all, the door latch must be working. However, it might be possible that there is a loose connection to it and vibration is causing it to momentarily open. If it is spade connectors, they might need tightening.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
chimes será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 280
