Where is the power steering pump?
Hello! lately when I turn the steering wheel the pump makes more and more noise. The hydraulic steering liquid level is ok, so I think I need to replace the power steering pump. But I've seen there's different pumps depending if the van has climate control system or just A/C, also depends on the gearbox (manual / automatic) so I think the best I can do is to find the power steering pump, check the OEM reference and then replace it, what do you think? Where can I find it? Thank you
Esta é uma boa pergunta?
@ruben88453 help us to help you. what year and what exact model is your Transporter? Does it have AC or climate control? Consider opening the hood and taken a couple pictures from the top and a few from the bottom. Post those with your Question. Let's see if we can figure this all out. Adicionar imagens a uma pergunta já existente
The PS pump is on the passenger side on the bottom of the engine. Yes, you will need to remove the AC compressor.
por oldturkey03
