Ir para o conteúdo principal
Repair guides and support for Kenmore washing machines.
1859 Perguntas Visualizar todos
kenmore elite smartwash HE4t error message F and SUD
My washer shows both error messages and will not finish through the spin cycle. I took off the front and emptied the drain with no luck
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
elisha, the SUD error on these machines is usually displayed when the motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. This could be caused by a bad pump, an extra heavy load, excessive detergent, or excessive suds. "If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check/ Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU"
You can remove the lower access panel and try and check the drain pump while it is in a drain cycle. If the pump seems to be buzzing or vibrating but no water is being drained then likely the pump is bad. If you have a multimeter available, you can check for resistance of the pump motor.
Esta resposta foi útil?
Pontuação 3
If this is a front loading machine, there is a device panel under the drum.
Get a 2x4 or two, and tip the machine back slightly, slide the wood or othe prop under the front
Remove the device panel
Get a bucket.
You should see a clean out, carefully open the clean out making sure the bucket is under it. I don't recommend pulling it all the way out unless your drum is completely empty.
Remove all the debris from the cleanout
Replace the cleanout
Lower the machine
I ran my similar machine empty to make sure no leaks. And to clean remaining suds out
Replace panel
You should be good to go.
Pontuação 0
1 comentário:
Thank you. I tried that and pulled out some debris. It still is not spinning. Any other ideas?
por
I am also having the same problem. The pump is functioning properly, there is no detergent build up, and the clean out has been cleaned out multiple times. Is there anything else I should be concidering before I simply give up and replace this machine?
Pontuação 0
Adicionar a sua resposta
elisha será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 80
Duração total: 22,233
