Ir para o conteúdo principal
power butten don't work
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Power button not working
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @yaredtaye!
Do you have a multimeter? If so, remove the power button board from the computer and follow this guide to check the button for continuity. If the meter beeps while you push the button, it is functional. You may have to experiment to find out which line is which. If it isn't faulty, you may have a problem with the cable connecting the board to the motherboard, or the motherboard itself. If indeed it is faulty, you should be able to find a replacement board on eBay or just solder a new button in.
Good luck!
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
yared taye será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 35
Ao todo: 644
