Ir para o conteúdo principal
Informações de reparo e desmontagem do iPad Pro 12.9" de quarta geração. Anunciado e lançado em março de 2020. Modelo A2229.
iPad Pro 12.9, USB Data Transfer Failure
iPad Pro, USB Data Transfer Failure
This is the iPad Pro 12.9-inch 4th generation model.
The connection to the computer via USB-C port is not working. My computer doesn't detect the ipad at all. (The same goes for ipad recovery mode.)
Currently, iPad is not a matter of computer trust because it has completed a factory reset.
I've also replaced the cable, but it's the same as the A to C cable or the C to C cable.
The symptoms are the same when I try on another computer (both Windows Desktop/laptop and macbook air M1)
Eventually, I disassembled the iPad and replaced the dock flex cable, but the symptoms didn't change. And I checked the logic board with a multimeter, but I couldn't check the short circuit/abnormal heat in components such as capacitors.(I have not yet checked the metal shielded part.)
Surprisingly, all other features are normal. There is no abnormal power off / panic full crash and the battery works well.
1. PD Charge - OK. Charging speed is also normal.
2. External Storage Connection - OK
3. External Monitor Mirrors - OK
4. USB-C Hub Connection - OK
I don't know the cause...Is it a failure of the USB IC?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I'm having the same kind of problem with my USB connects some things but not others now. Apple sucks.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
wellbinnn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 32
Ao todo: 362
