Ir para o conteúdo principal
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
Broken sensor connector on logic board
Ji Woong You,
Did you find a solution to the broken connector?
I have the same issue.
I need the connector, 2 pin that mounts to the logic board and mates with the LCD temp sensor cable
here is the part number for the cable, but I need the mating connector part number(connector solders onto the logic board).
IDENTIFYING NUMBERS
Apple Part #:922-9623
Printed Part #:593-1229-A
thanks, Lonny
Update (08/02/2018)
attach image of connector
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
@ant3 not sure where this old question popped up from:-) I am certain that you have made headway in the last 5 1/2 years. anyway, just for completion sake, the connector is a Molex 53261-8602. It is available at plenty of places like digikey.com and many others.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ant3 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 110
