Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
White screen of death problem
Hello, I have a MacBook Pro 1278 2009. When you turn on the device, a white screen appears and nothing else. I've tried all the ideas. Command + R and Command + Alt + R. But all that appears is a folder with a question mark inside. I changed the hard disk cable as well, to no avail. I hope you can help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@rayq2009 This "But all that appears is a folder with a question mark inside" means that your MacBook Pro does not find an OS. It's either a bad disk or the OS is not on it or corrupt. Check this post for resolution of this issue MacBook Folder With Question Mark
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
rayq2009 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 184
