Ir para o conteúdo principal
Roupas de frio Patagonia que mantêm você aquecido em dias frios e seco em dias chuvosos. A dificuldade de reparo varia desde o simples conserto de rasgos até o reparo mais complexo de divisórias.
Zipper pulled away from the jacket
The zipper still works on the jacket but on one side of the zipper the material pulled away. Suggestions on how to fix it?
It seem like the seams lost their adhesive and just pulled away
Update (02/23/24)
Imagem
This is the only place that I can find it. But as you can see the zipper has pulled away from the seam
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
I updated the original post to have the picture in it
por
Adicionar um comentário
1 resposta
There are several adhesives suitable for fabric such as Loctite vinyl, fabric & plastic; E6000; Sew No More; or, Patch Attach which you might use. You might try taking two stiff wooden slats slightly longer than the length of the separation and two or (better) three clamps and, with the zipper open, spread a small amount of your chosen adhesive on the portion of the zipper that you want to adhere to the fabric (you don't want to put on so much adhesive that it squeezes out when you clamp it), put a wood slat on each side and clamp it all together. You can probably get away with using spring loaded squeeze clamps but you can use whatever clamps you have on hand.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Oh, and if there is any old adhesive remaining on the separated area, you would want to do the best you can to remove it before making the repair. It's not obvious from your picture what kind of material you're working with so I hesitate to recommend a solvent. My go-to is acetone but I would be very cautious and try a tiny amount applied by the corner of a dried out alcohol pad. A product called Goo-Gone is probably safer than acetone and is also very good at removing adhesives.
por
It also occurs to me that you might try contacting Patagonia and asking them if there is a particular adhesive that they would recommend.
por
Adicionar a sua resposta
Logan Dunn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 47
Ao todo: 535
