Alto-falante de saída não funciona
Áudio de saída não está funcionando
Esta é uma boa pergunta?
@ornanmachado try a headset first. If you have audio on that, it is possible that you have either a bad headphone jack or a bad speaker. You also want to check the speaker mesh to make sure that it is not clogged. Clean it well with a soft brush etc. After that you want insert the headset and then rapidly remove it from the jack. Do that a couple of time since that can loosen a stuck contact. You can also use a few drops of high grade isopropyl alcohol and a few puffs of compressed air (air-in-a can) to get rid of whatever debris maybe in there. Then again insert the jack and then pull it out in rapid succession. Do that a couple of times.
If none of that works, it maybe time to replace the speaker. Replacement speakers are readily available at many online places and is not to expensive. To disassemble your Motorola phone and since iFixit does not yet have a guide for that, use a video like this to replace it.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@ornanmachado Experimente primeiro um auricular. Se houver áudio, é possível que o conetor dos auscultadores ou o altifalante estejam avariados. Também é necessário verificar a malha do altifalante para garantir que não está entupida. Limpe-a bem com uma escova macia, etc. Em seguida, insira o auricular e retire-o rapidamente da tomada. Faça-o algumas vezes, pois isso pode soltar um contacto preso. Também pode utilizar algumas gotas de álcool isopropílico de alta qualidade e algumas baforadas de ar comprimido (ar numa lata) para eliminar quaisquer resíduos que possam estar lá dentro. Em seguida, insira novamente o macaco e puxe-o para fora em sucessão rápida. Faça isso algumas vezes.
Se nada disto funcionar, talvez seja altura de substituir o altifalante. Os altifalantes de substituição estão facilmente disponíveis em muitos sítios online e não são muito caros. Para desmontar o telefone Motorola e como o iFixit ainda não tem um guia para isso, use um vídeo like this para substituí-lo.
Enquanto trabalha no seu telemóvel, tire muitas fotografias. Quando tiveres terminado, tira essas fotografias e cria um guia para o iFixit. Isso irá ajudar a próxima pessoa que tiver o mesmo problema que tu. É fácil e divertido criar estes guias. https://ifixit.com/Guide/new A comunidade iFixit agradece.
Reparação é guerra contra a entropia!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 13
