Ir para o conteúdo principal
Lançado em 24 de maio de 2021, o JBL Tune 710BT é um fone de ouvido Bluetooth elegante e ergonômico com som marcante.
The power Button is broken.
Yes I did.
I've serched on the internet for New Button but in vain.
Update (02/16/24)
If some one knows where can I buy a New power button. Please tell me🙂😉
Update (02/16/24)
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
3 comentários
@abdulkaderassad do you have it open and you have checked the power button? Do you have some good pictures of this so what we can see what you see?
por
@abdulkaderassad we need to verify that your headphones are the JBL TUNE 710BT If not, let us know the exact model.
por
Yes it is tune JBL 710BT
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Let us see the actual switch that's underneath the button. Unscrew that circuit board and carefully lift it out -- give us a photo or two. I'd be that it's an inexpensive momentary switch that you can replace with some simple soldering; depending on how the switch behaves, though, you might even get away with electrical contact cleaner and rapid presses.
Esta resposta foi útil?
Pontuação 1
1 comentário:
@abdulkaderassad totally agree with the above answer. I am certain that this can be fixed by soldering a new switch in place. Hardest part will be to find one that matches yours, but it can be done.
por
Adicionar a sua resposta
abdulkader assad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 35
Ao todo: 1,167
