Ir para o conteúdo principal
Versão apenas Wi-Fi do iPad Air de 2ª geração da Apple. Modelo A1566.
iPad Battery drain fast
Hello everyone, this is y mom's iPad (Device model iPad Air 2 16GB) and since the last week she's been experiencing some battery performance issues, basically it drains very fast even when is not used. I already turned off the background refresh to see if it helps but made no difference, then restore and updated the iPad with the software version 15.8.1 (it was already in the last iPadOS version when restored) and yet no difference once again. I checked using coconutBattery and shows 86% battery health. I had a similar issue with my iPad (9th Generation) a time ago, and was fixed just by turning off background refresh, so I thought it would help this one too. There is the picture of the battery draining by itself, and the iPad is completely clean, no Apps, no Apple ID, no files, nothing but the default apps.
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The battery health percentage isn't always the best way of determining if the battery needs to be replaced. Even though it says the battery is at 86% health, it still needs replacing.
Follow this guide:
Substituição da bateria do iPad Air 2 Wi-Fi
iPad Air 2 Battery
Imagem de Replace a 7340 mAh battery compatible with iPad Air 2 A1566 and A1567 model tablets. Part #020-8558. 3.76 Volts (V). Battery model A1547.
Produto
iPad Air 2 Battery
$49.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Alejandro Peñafiel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 22
Ao todo: 1,253
