Ir para o conteúdo principal
A quarta geração do Hyundai Elantra foi lançada em 2006 para o ano modelo 2007. O Hyundai Elantra foi vendido com o nome Hyundai Avante em seu mercado doméstico, a Coreia do Sul.
Slowed down after 20mph
Ater 20mph car slowed can not go. Passed
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi Tony,
First thing to do is get the car scanned for DTCs, or Diagnostic Trouble Codes. Anything that affects the car seriously enough to cause the kind of behavior you're seeing will set codes in the engine computer that should point you in the direction of the problem.
Here in the US, most auto parts stores will scan your car for free, or you can buy an inexpensive bluetooth scanner that will hook up to an app on your phone and do the scanning. You can find some of those OBD-II scanners for under $10 USD, and there are any number of free apps available; I use one called Torque.
While we wait for you to get your codes scanned, a check of the Hyundai forums shows that you're not the first one with that sort of problem. Here's one guy who found a solution when his car was doing that:
2006 3.5l Won't Accelerate Or Go Over 20 Mph - Hyundai Forums
Esta resposta foi útil?
Pontuação 0
1 comentário:
Fixed it was sterring wheel it had a ajustmeant slow hwy or fast its soomething i did not know
por
Adicionar a sua resposta
Tony Carxacco será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 253
