Qdo estou digitando aparece algo q parece trava tela mal atualização
Quando digito trava teclado!!como resolver??
Esta é uma boa pergunta?
@crislhp19756574 could be software related. Try a soft reset first.
If that does not work ty to safe it in safe mode. Follow the instructions from here
Once you're in Safe mode, try your keyboard and see if it now works normal. If it does then teh issues are caused by third party apps. You will have to remove those.
Of course, you could also factory reset your phone and see if that resolved the issues. The will set up your phone like it was when you first bought it. Careful since it will delete all of your files, pictures, SMS, contacts etc. Make sure that you have everything backed up and that you have your Google password as well as all the passwords to go into your phone. You will need that since you you otherwise will be locked out of your phone. To do a factory reset follow the instructions ffrom Samsung
If it still doesn't work then the issues could be a faulty touch screen For that you would have to replace the complete display assembly. Since iFixit does not yet have a guide for that use something like this video or the one from here Display assemblies are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@crislhp19756574 pode estar relacionado com o software. Experimente primeiro uma reinicialização suave.
Mantenha premido o botão Diminuir volume + botão de ligar/desligar ao mesmo tempo durante 7 segundos. Solte os botões quando o telemóvel vibrar.
O telemóvel deve reiniciar.
Se isso não funcionar, tente colocá-lo em modo de segurança. Siga as instruções de Aqui
Desligar completamente o telemóvel
Ligue o telemóvel e, quando aparecer o logótipo da Samsung, mantenha premido o botão de baixar o volume.
Se o fizer corretamente, será apresentado "Modo de segurança" no canto inferior esquerdo do ecrã. Se o "Modo de segurança" não aparecer, repita os passos anteriores.
Quando estiver no modo de segurança, experimente o teclado e veja se agora funciona normalmente. Se funcionar, os problemas são causados por aplicações de terceiros. Terá de as remover.
É claro que também pode repor as predefinições do seu telemóvel e ver se isso resolve os problemas. O telemóvel será configurado como estava quando o comprou. Tenha cuidado, pois irá apagar todos os seus ficheiros, fotografias, SMS, contactos, etc. Certifique-se de que tem uma cópia de segurança de tudo e que tem a sua palavra-passe do Google, bem como todas as palavras-passe para aceder ao seu telemóvel. Vai precisar delas, uma vez que, caso contrário, o seu telemóvel ficará bloqueado. Para efetuar uma reposição de fábrica, siga as instruções de da Samsung
Se mesmo assim não funcionar, o problema pode ser um ecrã tátil avariado. Para isso, terá de substituir o conjunto completo do ecrã. Uma vez que o iFixit ainda não tem um guia para o efeito, utilize algo como este vídeo ou o aqui Os conjuntos do ecrã estão facilmente disponíveis em muitas lojas online.
Enquanto trabalha no seu telemóvel, tire muitas fotografias. Quando terminar, tire essas fotografias e crie um guia para o iFixit. Isso ajudará a próxima pessoa que tiver o mesmo problema que você. É fácil e divertido criar estes guias. https://ifixit.com/Guide/new A comunidade iFixit vai ficar agradecida.
Reparação é guerra contra a entropia!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 59
