Ir para o conteúdo principal
Smart Tweezers LCR-meter or Digital Multimeter for Surface Mount Technology, SMD component characterization and PCB debugging
1 Perguntas Visualizar todos
SMD LCR Smart Tweezer Knock off compard
I was wondering how much difference a set of off knock LCR smart Tweezers match up to the real ones I see them on amazon like the mastech ms8910
http://www.amazon.com/Mastech-Ms8910-Res...
Do these get the job done and test in circuit? Any help would be appreciated.
Esta é uma boa pergunta?
Pontuação -1
1 comentário
John, just out of curiosity, what are using this far to measure any of your components?
por
Adicionar um comentário
1 resposta
Solução escolhida
I believe that the only way to answer this is to take the "knock- off" meter and measure multiple resistors with known values. than use a "Quality" meter and measure the same resistors again. Compare the values and you got your answer. Each meter will have a certain variance and each meter might be different. Measure, compare, evaluate....
Esta resposta foi útil?
Pontuação 1
5 comentários:
That's great idea thank you! I was wondering too if anyone had actually used the 2 I'm wanting to be able to test in circuit.
por
I would think that even the cheap ones are reliable within a certain tolerance. I just find the the cheap meter most certainly do not last as long as quality ones.
por
Thank you for accepting my answer. Good Luck.
por
+ Right off the top I see the one you linked to does not test L (inductance). It also doesn't test ESR or impedance like the products made by Advance Devices.
por
Click here for a web page a where they describe a hack/mod for the Mastech MS8910 Smart Tweezers to include voltage testing. They did a fairly good review on the product. They compared it's measurements to a Fluke multimeter on resistance and capacitance, over all it held up quite well with what it does measure. It should make a nice preliminary inspection tool, for the price. I'd own it for that purpose, especially with the voltage mod.
por
Adicionar a sua resposta
John será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 1,935
